Race bike fork springs upgrade?
nz_gixxer4_racer
Post by nz_gixxer4_racer »
Hi there guys, anyone running upgraded fork springs and keen to share feedback?
ie, spring rate, brand etc.
The standard progressive springs makes tuning sag impossible!
Variablevalves suck
Re: Race bike fork springs upgrade?
Post by Variablevalves suck »
Its difficult as so few race the gixer in the UK and most go to a specialist and get them set up for rider weight. You are on your own my friend!
youroddsox
Post by youroddsox »
Which forks are you using, the fully adjustable ones or just the pre-load adjustable? How much sag are you getting at the moment? In my opinion I wouldn't worry about the static sag too much as long as you have a fair bit more on the front than you do on the rear, not sure on the best static sag settings on a gixxer but at a guess with no rider the front may be close to 20-30mm from full droop on the front and around 5-10mm possibly lower wheel travel from full droop on the rear. This is a guestimate from a race 125 setting.
If you are not getting weight to transfer to the front quick enough on corner entry try a bit more rear pre-load and tuning the front pre-load and compression damping to stop the forks bottoming out under braking. Will probably need a touch more rebound to reduce the increased spring back rate at the front.
I would only really change the springs if yours aren't that consistent, you just don't like the progressive feel or you are close to the edges of the pre-load ranges while still using a good amount of travel.
Hope that is of assistance. Will heavily depend on the type of riding you are doing and your style as to what set-up works. Don't be afraid to also play around with the tyre pressures a bit.
