NC30 ignition problem - solved!
Posted: Wed May 20, 2009 1:27 pm
I need help. i was working on the electrics and when i went to turn the ignition on, nothing. i have a alarm with remote start and that works fine.
So im a bit puzzled, all the fuses are alright and everything seems fine when i use the remote start. I hadn't touched the barrel, i tried reconnecting the connector but nothing. The only thing i did is accidently touch the frame with a positive wire a couple of times with the ignition on.
pls help
steve
pls help
steve
