NC30 ignition problem - solved!
razghost
Post by razghost »
I need help. i was working on the electrics and when i went to turn the ignition on, nothing. i have a alarm with remote start and that works fine.
So im a bit puzzled, all the fuses are alright and everything seems fine when i use the remote start. I hadn't touched the barrel, i tried reconnecting the connector but nothing. The only thing i did is accidently touch the frame with a positive wire a couple of times with the ignition on.
pls help
steve
RickOliver
Re: NC30 ignition problem
Post by RickOliver »
You realise that there`s a single main fuse inside the red connector on top of the starter solenoid as well as the ones in the box...?
razghost
Post by razghost »
I think i have come across it before ill take a look
razghost
Post by razghost »
problem solved! cheers rick
