Headlights...
Headlights...
I'm getting the low beam relay done at the gargages on Thursday.
I have bought the adaptor rings from canada to make the headlight sit perfect, but i was what make of headlights people use after this mod?
Phillips? Osram?
Also which make and model sidelights?
Thanks Marcus
Phillips? Osram?
Thanks Marcus
Re: Headlights...
err I use halfords extreme brilliance, there ment to be 90% brighter than standard bulbs and are still fairly cheep (but i do work their)
Re: Headlights...
Thanks spike, i'll go and look in there.
What sidelights can i purchase (if there is any), model number?
Re: Headlights...
not sure the number their funny bulbs but got to halfrd and get someone on parts to look at the bulb and match it up to one, its not hard and we definetly sell them
Re: Headlights...
All H4 headlight bulbs seem to come with W5W sidelights, will these fit... and are they the correct ones?
Re: Headlights...
w5w is not right, thats the uk spec side light u want the jap one, there alot smaller, just go to halfords and take the one u have int he bike at the moment out and get them to match it.
Its located under the electrical connector for the main bulb just pull th wire and it will pop out
- Bike owned: nc30
Re: Headlights...
fitted 2 T5 leds in mine perfect fit. got a pack of ten off ebay
- Bike owned: 1990 NC30
Re: Headlights...
+1. Just fitted T5 286 white LEDs in place of the normal sidelight bulbs and they work perfectly.
