Issue with RVF fork top adjusters
viper_biker
Post by viper_biker »
Well, now that the RVF forks have been re-oiled and fitted to the bike, I went about looking to have them both adjusted the same and encountered a problem. The brass adjuster on the left stick only has 3 clicks where-as the one on the right has 6. Obviously this isn't normal, so where would the problem lie? The right fork is the one I had completely stripped and cleaned to check the internals, but the left one only had the oil drained and then fresh stuff put in. Anyone any pointers or ideas as to why there is so little adjustment on the left side than there is on the right? Thanks.
Re: Issue with RVF fork top adjusters
Could just be that the clicks are audible on the cleaner fork top?
Do they rotate the same amount per click?
RickOliver
Post by RickOliver »
Don`t have time to type it on here, but give me a ring and I`ll explain...
Rick
viper_biker
Quick chat with Mr Oliver and all should be sorted over the weekend (once I get a few able bodied friend over to help me out, thanks Rick.
royster81
Post by royster81 »
it sounds like the same problem i had with my nc30 forks and rick sent me a full write up on how to fix it nd it worked a treat, i think i printed it out and still have it.
