gk76a wheels spindle size
Posted: Thu May 14, 2009 4:05 am
by diogo
Hi
does anyone know the front and rear wheel spindle diameter please?
Thanks in advance
Diogo
Re: gk76a wheels spindle size
Posted: Fri May 15, 2009 3:36 am
by diogo
I know that up front is something like 15mm diameter but at the back I don't have the slightest idea and I don't have one to measure cause I'm not using the stock swingarm on my project, I'm using one from a 95 RGV 250...
if anyone knows, please...
Posted: Fri May 15, 2009 6:32 pm
by Variablevalves suck
Hi diogo,
Im sure its the same size as the RGV and think but not 100% that its 22mm. The swingarm pivot is the same at 20mm but you will find that the RGV pivot width is about 12mm less than the GSXR and you will need to line the chain run up/make spacers.
Chris.
Posted: Sat May 16, 2009 12:05 am
by M1KE
front spindle is 17mm cause they use 6203 bearings on the front wheel.
Rear Spindle is i dunno cause nowhere seems to even sell rear wheel bearings for 76s.............
Posted: Sat May 16, 2009 12:36 pm
by diogo
Thanks for all the repplies guys, that was helpfull :)
