3TJ reg rec same as 1WG?
Posted: Wed May 13, 2009 7:35 pm
by Holdup
As title says really, are they all the same or different?
Re: 3TJ reg rec same as 1WG?
Posted: Wed May 13, 2009 8:19 pm
by Evilchicken0
Different.
the 1WG is smooth and the 3TJ is finned
Posted: Wed May 13, 2009 11:47 pm
by Holdup
Ok what about the power, are they the same or different?
Posted: Wed May 13, 2009 11:58 pm
by Phil Norton
If the connectors are the same and the mounting holes the same distance apart then it'll work fine.
Unfortunately, I don't know if they are. I suspect that theres a good chance they will be, as most Yamaha reg/recs are basically the same size and connector. On my R1 I've had one from a R1, an FZR400 and a R6 so far :o
Posted: Thu May 14, 2009 11:00 am
by Holdup
Cool thanks
Posted: Thu May 14, 2009 1:45 pm
by Evilchicken0
I'm not sure ... the 1WG sits on the frame rail above the swing arm bracing ... I think the the 3TJ is on the subframe.
The 1wg will use the fram as a heat sink whereas the TJ is air cooled - I'd try and stick to the same type for the bikes as the first thing you'll know about it failing could be blown headlights and bulbs or duff battery ... which are expensive
Posted: Thu May 14, 2009 7:25 pm
by uniquefzrfreak
If you need one, I've got a spare 1WG reg rec knocking about, it's marked 4XV on the top
Posted: Thu May 28, 2009 10:18 am
by dustybin154
I had to get a new one for my 3EN1 FZR 400 and i ended up going to yambits.co.uk for £35 i got an RD500 reg rec and it works fine mate
