picking parts
buzzawak
picking parts
Hi all,
I am looking to replace the clutch friction plates. Problem is my bike seems to be a composite of 1wg/3en1/3en2
Is there a sure way to know which engine I have. I don't want to find I have ordered the wrong parts when I take the clutch cover off.
Taggyd
Re: picking parts
i think unless you have an sp engine you can use the same plates for all models, sp's had a different number of plates, (9?)
so would need a different kit. sure someone will confirm this in a bit!
Re: picking parts
Even though the SP has an extra plate the kit comes with one extra anyway. I've got a set of plates somewhere I think
buzzawak
Re: picking parts
So are we saying that all the models use the same friction plate except the sp has 9 instead of 8 ?
Re: picking parts
We're saying they all use the same friction plate inc the SP (when you get the EBC kit)
dobbslc
Re: picking parts
Any idea how long the springs should be as mine (3tj sp) are 37mm when the spec says 40 somthing mm??????.
Re: picking parts
Just renew the springs
