exup setting 3tj 400rrsp
				matfzr400rrsp
anyone know where to set the little arm to on the exhaust exup valve? aint got a decent manual so ive just set it to where i thought.
Re: exup setting 3tj 400rrsp
As you look at the pulley there's a hole at 9 Oclock .... stick a metal pin or small bolt between the two tougues and into the hole. Adjust the cables to finger tightness only ... and remove the pin
Turn the ignition on to check the exup opens and closes properly
				matfzr400rrsp
thought so, thats what ive done it to. thanks evil
