Page 1 of 2
NC29 Speed Restrictor, Clutch & Sidestand switch questions
Posted: Thu May 07, 2009 7:33 pm
by domski
OK, these questions refer to a CBR400RR-N which I am going to race.
1. Do I need to buy a 'magic box' regardless of whether I remove the speedo?
2. I've removed the left hand switch gear including the wiring for the clutch cut off switch and I will do the same with the side stand switch - will the bike start without these wires/switches connected?
The bike is stripped down and engine has no oil or exhaust on, so I'm not going to try and start it at the moment, hence the silly(?) question.
Thanks in advance ;)
Re: NC29 Speed Restrictor, Clutch & Sidestand switch questions
Posted: Thu May 07, 2009 8:33 pm
by tanuki
No you won't need the box but you will need to keep the sensor part of the speedo attatched or the bike won't rev you can't just remove the whole of the speedo.
Both the clutch and sudestand switches can be wired out with a loop of wire in the coresponding plugs, a bit of pissing about with a haynes manual and you will work it out.
Posted: Thu May 07, 2009 8:36 pm
by domski
Nice one Tanuki, thanks.
I know what you mean about the switches too ;)
Posted: Fri May 08, 2009 6:56 am
by leopard_pagan
> it would be far easier to fit a de-limiter kit instead of ripping out the sensor from the clocks. it is sammat i looked at doing years ago and it was not an easy job, these wernt designed to be removed.
the de-limiter is a easy plug in th back of the clocks loom that by-passes the limiter and you can remove the clocks completely with no worries of not revving past 5,000 RPM.
2 de-limiters available.
1 is a DIY set of free fitting instructions, but you get the parts.-
http://i18.photobucket.com/albums/b145/ ... ResMod.jpg" onclick="window.open(this.href);return false;
1 is a kit that comes with all the parts pre-built/sealed and fitting instructions for behind the speedo or at the ECU end of the bike. ebay Item number: 190304712689
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0304712689" onclick="window.open(this.href);return false;
Posted: Fri May 08, 2009 4:32 pm
by chrisja2
[quote="tanuki"]No you won't need the box but you will need to keep the sensor part of the speedo attatched or the bike won't rev you can't just remove the whole of the speedo.
Oooh bollocks, looks like its back to the wiring diagram for me then Billy. If i just put a resistor in line will that do the same job? Hmmm.....wheres davids phone number lol.
Just clicked on LPs diy link, answered my question in one easy pic. Thanks LP.
Posted: Fri May 08, 2009 4:41 pm
by domski
leopard_pagan wrote:1 is a kit that comes with all the parts pre-built/sealed and fitting instructions for behind the speedo or at the ECU end of the bike. ebay Item number: 190304712689
Well I've just bought one, so I hope it works :pray:
Thanks LP.
Posted: Fri May 08, 2009 5:25 pm
by leopard_pagan
no probs. yours will be in post tomorrow Dom
chrisja2, if you get stuck just PM/email me
Posted: Tue May 12, 2009 1:37 am
by paasker
I also removed the LH switch gear from my nc29 trackbike. Haven't done anything to the clutch switch... it still starts and rides fine.
By the way, what is theclutch switch for??
Posted: Tue May 12, 2009 4:07 am
by greggo
Clutch switch allows you to start the bike in gear. It's there to prevent you turning the motor over in gear and damaging your starter.
As this is a track back you don't need a speedo, or a delimiter, or to keep the bloody little circuit in the speedo clock. There is no reason to keep the speedo. If you've got time to look then you aren't feckin riding fast enough. :poke:
Take the ORANGE and BLUE wire from the CDI, and wire it directly to the +ve terminal on your battery. Thats what I was advised to do by the shop that started the 400 class in Australia, and how my bike has run on a std CDI since. (3rd year and counting). Then I hacked the speedo off my clocks and threw all that extra weight in the bin.
If you wanna wire it up to be keyless and throw away that pesky ignition barrel (theres a kilo there) I have a few photos and a walk thru for that. Should be up in the 'how to' section when it comes to life.
Posted: Wed May 13, 2009 4:30 am
by paasker
Will that derestrict the bike or how are you supposed to understand that?
