NC30 Cooling Gurus - HELP! :)
Posted: Tue Apr 28, 2009 5:37 pm
Hey All, Got my NC Sorted a few months back, But i've had some serious cooling issues
Can't make any major journeys due to the bike overheating and pissing it's coolant all over my rear tyre out of the overflow, so i sorted myself out with an overflow bottle which i can drain & Cleaned out both radiators/Hoses and the heads :)
Problem is though, As soon as the system has built up pressure, The radiator cap opens and starts to fill the reservoir which just means i lose coolant out the system and the bike gets even hotter. As i understand the cap opens at 1.1 Bar, So i made myself an adapter for a pressure gage and stuck it in the hole for the temperature sender on my thermostat, Bike happily runs the pressure up to 1.1bar with the standard radiator cap on, which then opens and relieves the pressure and pisses water into my overflow bottle, after 5 minutes of running my overflow bottle was full.
I then sealed my radiator cap so it couldn't release the pressure, and the system built up to about 3 bar in about 2 minutes, at which time i figured i'd stop since i didn't want to make one of my hoses go pop
So, i'm just thinking the systems always going to just hit 1.1 Bar and throw all the coolant away, which makes the bike even hotter, Is there some sort of relief valve that will keep the pressure from opening the cap and keep my coolant in my bike rather than all over the road?
Any Suggestions?
This is driving me nuts, any help appreciated :)
Cheers, Nick
Any Suggestions?
Cheers, Nick
