				Cam Chain
				Posted: Sat Apr 25, 2009 12:57 pm
				by buzzawak
				Hi All,
I would like to replace the cam chain. Is it possible to do without stripping down the whole engine ?
Also does anyone know the DID produce code for the 1wg engine cam chain?
Thanks all
				Re: Cam Chain
				Posted: Sat Apr 25, 2009 8:56 pm
				by Evilchicken0
				Why ????
Yes you can do it without a full strip you simply use a weak link chain.
				Re: Cam Chain
				Posted: Sat Apr 25, 2009 9:50 pm
				by Taggyd
				pm lajracing, he can get you one and probably at a discount for members!
				Re: Cam Chain
				Posted: Sun Apr 26, 2009 10:17 am
				by Evilchicken0
				Go through the bike and put together what you need then if you can't get it in Aus sort it out over here and only pay once for postage
				Re: Cam Chain
				Posted: Mon Apr 27, 2009 6:05 am
				by buzzawak
				Lajracing has pm me to say he can help with stuff that I can’t get in Australia. I will take up his offer when I have frustrated the available venues here. Problem is the postage from UK to Aust is prohibitive. I am determined to have this FZER looking and riding tops so I may have to accept the additional costs involved.
				Re: Cam Chain
				Posted: Thu Apr 30, 2009 10:18 pm
				by Motorcycle Solutions
				Just to let you know if i send it by email and doesen't weigh 2kg's it will cost about £7 - £15 pounds and over that weight of 2kg i would recomend a biggish order to get your moneys worth.
				Re: Cam Chain
				Posted: Thu Apr 30, 2009 11:27 pm
				by buzzawak
				lajracing wrote:Just to let you know if i send it by email and doesen't weigh 2kg's it will cost about £7 - £15 pounds and over that weight of 2kg i would recomend a biggish order to get your moneys worth.
Hi Lajracing, thanks for the info. Once I have sorted out a list of what I need I will be in contact.
I didnt know you could sent a cam chain via EMAIL?
				Re: Cam Chain
				Posted: Fri May 01, 2009 7:48 am
				yes all i do is take photo and then see you tryand fit it
i will send it via air mail is the words i was asking for
