G76A valves shim or screw type?
nz_gixxer4_racer
Post by nz_gixxer4_racer »
Variablevalves suck
Re: G76A valves shim or screw type?
Post by Variablevalves suck »
Hi,
The adjustment is via shim. They are the standard small shims used on loads of modern bikes. I used Triumph ones as the dealer is the closest shop to me and they cost about £4, just go and speak to your local bike mech and if your lucky they may have the correct size in their work shop. Just push the arm across on its spring and remove them with a magnetic tool. I use two tools so one takes out and one puts the new shim in otherwise you end up droppin shims in the motor when your swoppin them over.
Chris.
Variablevalves suck
Think Gazz has recently done the valves on his gk76 so if you need any pointers im sure he can help you out.
Gazz
Post by Gazz »
nz_gixxer4_racer
Just as VV Sucks says, shim type easy to do, prob the easiest I have worked on, I swapped a few around and did an exchange trade with the others with my local bike shop. Triumph make smaller ones than Suzuki should you need them.
Gazz
gsxr400 racer
Post by gsxr400 racer »
buy a after market shim kit from HOT CAMS in the right diameter kit comes with tons of spares to get you riding the same day. About $150 USD
