starting problem
Carter
starting problem
Post by Carter »
well here's the first of the problems on the new track tool, it's a gk76a it'll turn over but there's no spark at any of the plugs....all fuses are ok as are all the connections. any ideas :?:
Awynn
Bike owned: GK73a, CB250, NS125R-K, CLR125
Re: starting problem
Post by Awynn »
CDI - Ignition coils - Signal generator - or anywhere in between, good luck.
Carter
Post by Carter »
Awynn wrote:CDI - Ignition coils - Signal generator - or anywhere in between, good luck.
got a feeling it's the cdi, doubt both coils are gone....though knowing my luck. call me thick but what's this "signal generator?" (oh how i'd kill for a manual :cry: )
Awynn
Post by Awynn »
I am not greatly familiar with the GSXR electrics yet but the I believe it is usually a magnetic pickup from the engine's flywheel (sends a signal to the CDI so it knows where the pistons are so it can sort out the timimg or something to that effect) :|
Awynn
Post by Awynn »
Carter
Post by Carter »
Awynn wrote:I am not greatly familiar with the GSXR electrics yet but the I believe it is usually a magnetic pickup from the engine's flywheel (sends a signal to the CDI so it knows where the pistons are so it can sort out the timimg or something to that effect) :|
cheers for that, was begining to think i should of got a vfr....not much interest in the gixers on here! just looking at the spec sheet, is it right that the rear should be a 160? got a 150 on at the mo. ta
TeamGSXR
Post by TeamGSXR »
Carter wrote:cheers for that, was begining to think i should of got a vfr....not much interest in the gixers on here! just looking at the spec sheet, is it right that the rear should be a 160? got a 150 on at the mo. ta
Ummm don't swear round here (although vfr was my 1st choice but couldn't resist a cheap Gix4!).
I have a 160 on mine.
Austyn
Post by Austyn »
You'll Be alright with either a 150 or 160 rear. Standard sizes are 120/60-17 Front, 160/60-17 Rear (GK76)
Carter
Post by Carter »
well cdi is on and the plugs now give off a nice spark :D no fuel getting through now, don't think it helps having been stood for so long. any words of wisdom???
garynortheast
Post by garynortheast »
Get the carbs off and apart. Clean them out thoroughly, blow the jets through with an airline. Replace every single o ring on them you can find.
