HOW DO YOU CLEAN A CHAIN (WITH O RINGS)
sportspromatt
want to clean chain and sprocket soon, for NW200, whats the best thing to use that doesnt damage O rings,
should I use petrol, or white spirits!! or anything else
Re: HOW DO YOU CLEAN A CHAIN (WITH O RINGS)
well chain cleaner - does what it says on the tin but it's pricey for what it is.
Parafin is about £8-10 gallon, you can get it at a hardware shop.
Don't use pertrol
Don't use pertrol
- spooky
- Bike owned: nc24
Mine has gone rusty from sitting out can it be cleaned up?
- vfrman
- Bike owned: NC30, 1098s
It would be best to replace it. You can try to clean and lube, but I would definately inspect it for kinks or tight spots.spooky wrote:Mine has gone rusty from sitting out can it be cleaned up?
- spooky
- Bike owned: nc24
Probably should though its not heavy rust so it might clean up ok.
sportspromatt
Thanks Evil,
yep chain, spockets were new last year, just want to get the old chain lube off and replace it with fresh stuff,
Oh, didnt know you could get chain cleaner
a litre of parafin it is then, thanks again.
spooks, try placing the chain in vinegar, I bought vinegar in vivo at 32p per 500ml
it cleans surface rust off chrome etc, and metal, if soaked in it long enough. cleans up chrome plated bolts etc.
its also nice on chips!!
Thanks again lads, hope this helps!
- Sligeach
go on tinternet and look up motocross chain cleaning brushes as you can purchase specfic brushes that clean 3 sides of the chain in one sweep
- spooky
- Bike owned: nc24
Vinegar you say, hmmm I was told diesel would remove rust also. I'll try them out before forking out for a new chain. It was brand new but had sat out all year. Not even turned in anger lol.
wullvfr
- Bike owned: zx9r c1
wd40
most people may disagree and say it actually does more harm than good but thats a load of bollocks
been doing it for a long time now and never had any issues....it does a fab job of cleaning the chain,try it.
william
william
sportspromatt
DONT USE DIESEL
it will distroy the rubber o rings in the chain, and will distroy anything made of rubber
