VFR 400 NC 24 Conversion 17'' Wheel
XL-Twin
I asked this Question before but no one answered :
Is it possible to fit any 17 '' as rear and front wheel ?
Do i have to change the swingarm from NC24 and use a NC30?
And could i also use the NC30 forks in the NC24 frame ?
Has anyone with an NC24 ever done this before ?
Re: VFR 400 NC 24 Conversion 17'' Wheel
Howdo,
You cannot exchange the swingarms without some modifications.
Practically nothing can be used on the nc24 from the nc30.
XL-Twin
Did anyone do it before ?
Some modifications would be ok....but not to much !
Do i have an chain off set when use the NC30 swingarm ?
I now how to fix a chain off set a a normal dual arm but not with a one armed swingarm !
It is not possible to use a wheel of the vfr RC 36 for example is it ?
Is has the same mountings like NC24 BUT the swingarm would be to small right ?!
Spike16
iv seen pictures of an rvf race bike with what looks like a 24 rear wheel (similar style to nc30 but 4 stud) , baffled me too
XL-Twin
THe one with four stud is also used in the ''bigger'' bikes like the RC36 !
But that dont make sense in a RVF cause you have to change the swingarm or atleast the hub tu geht a 1/2 '' bigger wheel !?
Do you know where to finde this picture ?!
You can fit, with a hub modification, the old style 5 spoke 750 rim to the NC30 and 35.
May be also possible to do the same modifications and fit the 750 rim to the NC24.
NC24 is a 4 inch rim as standard isn't it?
If I owned one I would make the best of what I had already rather than trying to change it for NC30 bits.
As it happens, I have an NC30..
So I am sorted already
XL-Twin
Normally the NC24 has 3,5.
So i guess the swingarm is to small for a lager wheel!
Pherhapsanother hub will fit a bigger rim BUT i thing i have an off set then !?
The NC24 was for free and i have no money for another bike so i thought to modiefie it would be a good way !
Spike16
http://www.bucketsnbits.co.nz/race1.html" onclick="window.open(this.href);return false;
rvf race bike under there, only found the sight searching for tz250 pictures, think im gona copy the silver bikes colour scheme for m race fairings but with blue instead of blue
Interesting pics there Spike.
I doubt any racer is going to fit a 3.5 inch rear rim. I'll guess that this is a 750 rim and that the dude has modded the hub the same as Rick has done but for the older wheel rather than the newer 5 spoke.
XL-Twin
Has someone else an idea how do it ?!
I know that the NC30 swingarm will fit into the NC24 frame !
BUT i dont know how much chain off set there would be !
