Where does this hose go..? (LHS of the carb / engine area)
AliasOmega
In the picture, the dangling one.
This is part of the T piece from the tank vent pipe, drops down the LHS of the airbox, into a T, then this end if free.
Cant remember where it goes, the airbox catch for when you overfill the tank has a hose on it already.
Where does it go.?
Where does it go.?
- spooky
- Bike owned: nc24
Re: Where does this hose go..? (LHS of the carb / engine area)
Expansion tank overflow tee piece. I think!
AliasOmega
No, expansion bottle has one that is thinner
I have other pictures of the bike from the past, but i cant see where the hose went. Must of gone somewhere.
AliasOmega
An old picture, you can see it folded over going onto something..
Ive had a look through the manuals i have, no info.
- spooky
- Bike owned: nc24
Sorry I was thinking it would be like the nc24. It go's there.
Its only an overflow/vent anyway, just make sure its pointed away from the rear wheel.
AliasOmega
Added another picture,
It needs to go onto something, it was on something or i would of removed it when i rebuilt the bike ages ago.
It does not contain water, but fuel vapour from the tank.
Will pop the tank off and spend 20min looking before taking it out on a test run.
- aaron0288
I think Spooky's right. It just dangles around near the side stand I believe.
If there's one thing I've learned, it's that life is one crushing defeat after another, until you just wish Flanders was dead.
- CRM
its the breather. on the left near the front of the carbs its connected to a T piece, half goes under the airbox and actually hooks to the tank breather, the other half goes to the underside of the tank breather if i recall, and the lower bit exits in the bracket near the sidestand
AliasOmega
Well, the T piece is next to the carbs, on the LHS.
I side of that goes up to the tank breather (thats on the top)
The other at the moment is routed into a place near the airbox to keep it out of the way whilst i took the bike out on a test ride post missfire.
I could smell fuel when i stopped, i had filled up earlier, so i thought the fuel vapour will be going down the pipe, too the T, then back up the hose as its higher,and thats what im smelling.
CRM, i did look at putting onto the underside of the tank, but thought that on top of the airbox, on the LHS there is that tray to catch something. I figured this must be that thats for, so left the hose off.
Your probably right, i probably did put it onto the underside of the tank. Ill look at the parts drawings again, see if i can get an idea of it all.
AliasOmega
Ok, looking at the parts thing, doesnt really clear things up.
Unsure on the lengths of the pipes, but surely a little too short for this.
Back to the drawing board i think.
