Anyone want to buy my 3TJ hybrid
plodder
Post by plodder »
I'm considering selling my hybrid and wondered if there's any interest on here.
I'm looking for £1200. If you're genuinely interested and have cash available then PM me. I'm kind of testing the water as I'm thinking of selling this and my FZR1000 and buying a nearly new bike. But I'm not in the habit of giving away perfectly good bikes as I'm sure you'll understand. MOT is good until the start of september.
Spec is:
FZR600R Foxeye engine
Fzrtim's engine mounting plates with 6mm ground of the left hand cylinder head mounts to maintain allignment (Tim had to make a mirror image plate for the left side because of this). Right hand engine mount collars from a FZR1000 EXUP as they're shorter, so the bolts don;t stand proud.
FZR600R Foxeye carbs
FZR600R Foxeye loom & CDI
3TJ radiator with outlet nozzle bent slightly outwards to prevent hose clash with pipes. Home made Tee piece for oil cooler hose. Outlet radiator hose protected with glass fibre tape just to be sure.
YZF600 Thundercat Delvelic downpipes with 2 header gaskets in each port (no pipe bending required). The rear pipe mount lines up just below the rear engine bolt on the Thundercat pipes, so easy to make a bracket.
FZR1000 EXUP exhaust link pipe & random carbon can. There's some packing to match the link pipe to the headers.
FZR1000 EXUP fork bottoms mated to 3TJ stanchions with FZR1000 EXUP damper cartridge to stiffen up the damping.
R1/R6 blue spot calipers with EBC HH pads & braided lines.
FZR1000 EXUP front wheel powdercoated black (rear 3TJ wheel powdercoated to match).
Avon Viper supersports.
FZR1000 EXUP EBC prolite disks with polished centres.
R6 shock with Oolit's extension piece
YZF750 clocks
Modified 3TJ airbox (corners melted down a bit, snorkel removed, lip dremmelled near snorkel bolts and filter held in with wire).
Front of tank raised 10mm to get some extra air in.
FZR1000 EXUP left hand switchgear
FZR1000 EXUP headlight with pilot bulb in it (I'm fed up of paying £16 a bulb with the projectro light)
I think that's it. In case you're wondering why so much FZR1000EXUP parts, it's because I usd to break them and have loads of this stuff lying around.
plodder
Re: Anyone want to buy my 3TJ hybrid
Post by plodder »
Not a dickie bird of interest.
How much should I be valuing this bike at then?
Post by Evilchicken0 »
Oh- I'm interested in the bike until it comes down to cash and having somewhere to store it.
I think the problem is the people here have FZR's and probably aren't looking for a hybrid. Trouble is I'm not sure where you'd look to sell it.
plodder
Post by plodder »
It's easy enough to stick on ebay evil but that costs money.
Yup - and you probably won't get the value of the bike / work you've put in. I'd say it's best put in MCN.
Seriously - I would be interested if I didn't have my 3TJ and 3EN2. The TJ is probably a keeper for now and the 3EN2 needs an MOT then I'll sell it .... and be in the same boat as you, if I wasn't soooo lazy (and look after my other bikes) I'd have done it by now.
nutz
Post by nutz »
Hi mate, do you still have it? and where are based.
Thanks Steve
plodder
Post by plodder »
I still have it and I'm in Stockport, Cheshire
plodder
Post by plodder »
Not that I'm necessarily thinking of selling at the moment.
plodder wrote:Not that I'm necessarily thinking of selling at the moment.
Have you fallen in love all over again :grin:
SHimmer45
Bike owned: GPz500s KR1 KR1-S
Post by SHimmer45 »
That 3EN still hiding away then :grin:
