wont start and battery isnt charging
rickstar
Bike owned: gsxr 400 gk76a
Post by rickstar »
i have a gixxer gk76a, the bike will start off the button, after driving a few miles if i turn it off it wont start i have to bump start it. its like the battery isnt charging when i drive. please help!
TeamGSXR
Re: wont start and battery isnt charging
Post by TeamGSXR »
Measured the voltage across the battery before starting? Then with the engine running and lights on?
wullvfr
Bike owned: zx9r c1
Post by wullvfr »
first of all,check the voltage at the battery with the bike running @ 5000rpm.it should be between 13.5-15volts.14 is about average with a good charging circuit.
if there is no charge rate at all meaning the volts actually drop slightly and do not rise then the problem more than likely lies with the reg/rec.
if the volts do rise but hardly at all,then the alternator could be on it's way out.
out of curiosity,when you ride for a few miles is the battery fully charged before leaving?????the reason im asking is a fully charged battery will power your bike for a good whule so long as you dont use the lights,if you were using your lights and the charging system was faulty then it would not last as long.
i ran my bike a few yrs back with a faulty reg/rec and i could manage 50-60miles very easily before having to charge the battery.
william
rickstar
Post by rickstar »
hi yes the battery is fully charged when i leave, i will ride about 4miles turn it off and it wont start i have to bump start it.also if its cold and struggling to start after 3 or 4 tries sometimes the battery runs out and have to bump it. (hope that made sense!) thanks
wullvfr
Bike owned: zx9r c1
Post by wullvfr »
battery may be goosed.do the charge rate check first and see what the results are,then take it from there.
william
tractor664
Post by tractor664 »
may sound stupid but remove the strip across top of battery (the bit that says DO NOT REMOVE ) check fluid level in cells had simillar prob with mine start a couple of times then appeared flat leave for a while and would turn over again battery was bone dry if yours is like this as a temp measure fill cells with acid from an old battery and charge for a while then try again if better the only real option is a new battery (approx £30 check ;) local motor factors NOT HALFORDS etc ;)
rickstar
Post by rickstar »
hi its a MF battery, i opened it and there is no liquid should it be full?
Awynn
Bike owned: GK73a, CB250, NS125R-K, CLR125
Post by Awynn »
It is most likely a "maintenance free" battery which when filled with acid originally it soaks into fibre matting and I think gels in place so there should not be any loose liquid inside? To be honest I do not know if prising it open and adding acid will do anything or not...
edit: oh yeah you said it is MF didnt you.
rickstar
Post by rickstar »
yes its a 'maintenence free' battery is it sopposed to be empty inside, theres like a foam at the bottom. thanks
wullvfr
Bike owned: zx9r c1
Post by wullvfr »
being maintenance free is exactly that,you should never have to do anything to it.it does not mean however that the battery can never give up the ghost.
do you have a multimeter?
if so,do the voltage checks.
william
