diode
Posted: Sun Apr 12, 2009 10:32 am
by beefyvfr
my clutch diode has packed up...does anybody know where i can get a new one from..........
Re: diode
Posted: Sun Apr 12, 2009 11:50 am
by shaun1988
by clutch diode do you mean the little black switch that is attached to the lever?
if so davidsilver spares sale them new, they dont cost much
can some 1 tell me what this is for and if i actually need 1? as i have got ISR levers so there is no longer a place for this switch to be attached, does it have to be used? what happens if i dont use it?
Sorry for thread hi-jack
shaun
Re: diode
Posted: Sun Apr 12, 2009 2:30 pm
by Smev
I think the diode is a small block thing on the wiring loom - not far along from the rec/reg towards the back of the bike?
Smev
Re: diode
Posted: Sun Apr 12, 2009 7:05 pm
by hunter
If it's on the brake lever,then it's a a brake light switch.
Re: diode
Posted: Sun Apr 12, 2009 10:29 pm
by shaun1988
no this switch is attached to the clutch lever not the brake lever, i guess you guys havent got them on ur nc30? or just not noticed it lol
Re: diode
Posted: Sun Apr 12, 2009 11:19 pm
by wullvfr
are you referring to the clutch switch which is part of the safety circuit,meaning you can't start the bike if in gear unless the clutch lever is pulled in.
william
Re: diode
Posted: Mon Apr 13, 2009 7:12 pm
by shaun1988
ahh thats what it is, so its not really needed then? or do i need this for mot?
Soooo sorry for the thread hi-jack
Re: diode
Posted: Wed Apr 15, 2009 12:16 am
don't need it for MOT.
Just means you won't be able to start the bike in gear, even if you pull the clutch in. (unless its been bypassed) then you'll be able to start it in gear even without the clutch pulled in (bad)
Re: diode
Posted: Wed Apr 15, 2009 12:20 am
by wullvfr
Neosophist wrote:(unless its been bypassed) then you'll be able to start it in gear even without the clutch pulled in (bad)
funnily enough i bypassed mine on the nc30 earliy last year,cant remember why i did it but thankfully i always remembered that i had done it.....
william
