newbie with nc30 issues
mikevo
Post by mikevo »
Hi new to site have bought a none runner, was told just exhaust needed refitting as it was reassembled without new crush gaskets, refitted the exhaust and tried to start
Took awhile to get it to start maybe 30 seconds with full choke, bike ticked over ok but soon as you try and rev it stalls ,so let it warm a little , after about 1 minute tried rev again and you have to blip throttle quite a bit to make it rev then it will rev to 6000rpm then splutter a lot the rev on
took bike out and was very hard to pull away had to slip clutch to get revs up pulls up to 6000 but wont rev past it
any ideas
all advise gratefully accepted
regards mike
ps it fitted with i think one of the cheap chinese cdi !!
wacker315
Re: newbie with nc30 issues
Post by wacker315 »
Sounds like the same problem to me matey! :cry: Once my bike is warm its fine but when its cold it does exactly the same.
Sean
MexicanGringo
Bike owned: '30
Post by MexicanGringo »
U need to clean the plugs and clean the carbs out probaby as well.. Plugs should make an instant difference but if still not running well at operating temp u'l have to clean the carbs which really isnt that difficult of much of a hassle.. Not sure of the cdi, doubt it causing the prob tho, just get the basic service done with oil & air filters & should run fine
mikevo
Post by mikevo »
thanks for reply
the bike has only just had new plugs and full service ,and carb cleaned and supposed set up :(
is there anyone local to maidstone kent who would be up for taking a look , or best place to take it , have not the time to spend ages trying to rectify it
MexicanGringo
Bike owned: '30
Check that fuel is flowing properly from the tank by attaching a tube to the vacuum nipple and suck, if fuel flows its fine.. Perhaps the person who cleaned the carbs has fiddled with the idle screws? Theres a lot of things to check to get fuelling right, float levels, diaphrams moving freely, all air passageways clear, fuel actually getting in.. Another thing to try is take the air filter off and run it briefly without it, see if this extra air helps cos might be caked air filter tho service should av replaced that.. & obv youv got fresh fuel in the tank!
mikevo
Post by mikevo »
removed carbs and cleaned all
fuel tap vacum ok
air filer is new
when reassemblied all same infact worse as now it will hardly ever rev from idle
also when you wide open throttle in back fires on at least 2 cylinders
someone local to kent want to take a look ? will pay cash ;) need it running asap as have no other transport and being made redundent in couple of weeks and need it to get to job interviews please please help ,and dont trust bike shops around here
MexicanGringo
Bike owned: '30
Ok obviously theres fuel going thru fine, so the fault possibly lies with the ignition system.Have you checked that all plugs are sparking? Backfiring may be an indication your getting spark at the wrong moment when valves are open, that cdi may be the problem, does it have a brand name? Someone here might have a spare cdi you try out??? Another thing to check if whether the reg/rec system is working properly, check the voltage across the battery @ 5k if you can get it to rev there, otherwise just make sure the battery fully charged& outputting at least 12.5v. Check whether the coils are getting charge by connecting multimeter at coil inputs& grounding to frame.. I think the prob lies somewhere in electrical system/ignition system. oh and also make sure you dry the plugs if youv turned it over a lot without it firing as they flood easily
Has it got a speedo? Does it have a derestrictor?
If it is cutting onto 2 cylinders at 5.5k revs then this is the limp home mode that is triggered when the CDI doesn't see a speedo attached.
Might be as simple as that?
mikevo
Post by mikevo »
the speedo is working and has a reduction gearboxs on it to convert to mph
the main issue is it wont rev from idle at all at moment :(
you need to know that it has a standard airbx, std carb settings and so on.
There must be someone down there that can help you out.
a few hours would see this sorted I am sure.
Thinking on - regardless of the converter - this issue is not speed related, it is electrical.
no idle is bad enough though... has the idle screw been set right?
