Page 1 of 2
hybrid with r6 shock.
Posted: Fri Apr 10, 2009 6:59 pm
by hunter
I,am hoping someone will giv me a measurment,
i am fitting a nc30 swingarm to a 3tj frame,and i need a measurment from the centre of the swingarm spindle to the floor,the bike must be upright off stand and on level ground,and measurerment must be taken from centre of spindle.please.
Could,you also tell me,show me, what fits between the frame rails behind the the petrol tank,is it a seat brkt,tank brkt,it's held on with 2 6mm bolts.thank's in advance.
see photo.
Re: hybrid with r6 shock.
Posted: Mon Apr 13, 2009 1:12 am
by Evilchicken0
The fuel tank ... it has a boss welded onto the bottom and a long bolt through it that squeezes the frame together
Posted: Mon Apr 13, 2009 11:26 am
by hunter
Evilchicken0,you say it's a long bolt but the frame is threaded both sides.
Posted: Mon Apr 13, 2009 6:44 pm
by fzrtim
I think the last owner of the frame must have done some mods on the frame judging by the fact they seem to have tapped out all the holes!
Just a long bolt on both of mine too!
Posted: Mon Apr 13, 2009 6:57 pm
by hunter
Tim,this is a 4dx frame,just like the top shock mount they semm to be different to other 3tj frames.
Posted: Mon Apr 13, 2009 8:46 pm
by fzrtim
With my 3tj with a standard rr shock on the 2nd hardest spring load setting i measured 375mm from floor to centre of swingarm spindle (on level ground and with bike off stand ect). Hope this helps!
By
twaudby, shot with
PDR2300 at 2009-04-13
By
twaudby, shot with
Posted: Mon Apr 13, 2009 11:04 pm
by hunter
Cheers m8,just what i wanted to see on the tank.
But the measurementi was hoping to get was as in photo below.
Also,one other thing is the measurement, eye to eye of your r6 shock when fitted no rider on board.
thanks again.
Posted: Thu Apr 16, 2009 6:49 pm
by hunter
Posted: Sat Apr 18, 2009 8:09 am
by fzrtim
Sorry for delay in reply. The bolt hole you have pointed out in the last drawing is actually the rear subframe top mount. All the same i measured that to the floor. It measured 715mm to the centre of the bolt.
I have a spare standard 400rr shock lying around the garage, when i locate it i will measure the length of it for you!
Hope this helps, Tim
Posted: Sat Apr 18, 2009 3:29 pm
by hunter
thank's for that one tim,i can get on a bit with the nc swingarm conversion,
the shock measurment has got to be the r6 shock,and when fitted to the bike,again no rider just the weight of the bike,and from mounting eye to eye,no extention piece
