FZR400 1WG 1987 Fairings
				greeny_3
FZR400 1WG 1987
I have the above bike, and need some new fairings for it. Does anyone know if fairings off of other models will fit, ie off a newer 400 or off of any 600's?
Thanks in advance,
Dave
Thanks in advance,
Dave
Re: FZR400 1WG 1987 Fairings
That's a Genesis isn't it ???
If it has the split fairings then FZ600 should fit and retain the split
FZR600 and FZR400 1WG should also fit but I can't garantee it - these are one piece
Get some plastec as you will probably have to repair whatever you find to some degree
				greeny_3
It's this one...
http://s127.photobucket.com/albums/p123 ... C_0032.jpg
So just to make it totally idiot proof for me, could you list which models would be a direct fit, and what years up to?
Fzr400 1WG 1987
FZ600 around 1986 to 88
But the fairing on that bike looks good.
				greeny_3
Great stuff, widens my options a little.
Oh yeh I like the colour scheme on it, and I'll keep it the same. But if you get up close you can see how bad it is, and it's like it all over. And I have one missing too!
Thanks for your help
				greeny_3
I've seen that there are two styles of tail section; a 1 piece one that I've got, and then a 3 piece one that slots together. Would the 3 piece one fit my bike?
Thanks,
Dave
						Thanks,
Dave
Um ... maybe ... tail sections bolt to subframes which may or may not bolt on to your bike, I'd have to say that it probably won't. It's best to try and get one that's a replacement for your bike.
If the panels are cracked then you can try to repair them with Plastex
