CAMS: CB400RR vs CBR400RR
Posted: Wed Apr 08, 2009 4:34 pm
by bbanna
Does the CBR400RR use the same cam as the CB400RR?
Curious to know if Honda changed the CBR400RR cams to be higher performance cams. If they are the same, then I am safe to use any CB400RR thru CBR400RR cam in my project bike.
Thanks.
Brian
Re: CAMS: CB400RR vs CBR400RR
Posted: Wed Apr 08, 2009 11:40 pm
by Cammo
Do you mean CB400 (NC31) vs CBR400rr (NC29)?
If so the nc29 cams are higher performance than NC31 and can be swapped, might need some other changes.
There's a cb400 racing in Oz that uses nc29 cams.
Posted: Thu Apr 09, 2009 9:35 am
by stimpy
or did u mean nc23cams in a 29
i raced that cb...it isnt that quick
stimpy
Posted: Thu Apr 09, 2009 11:28 am
by Cammo
Is that Harleys bike Scott?
The CB needs all the help it can get!
How did it handle?
Posted: Thu Apr 09, 2009 1:53 pm
by stimpy
yeah harleys bike...umm,i only saw it in front of me for 2 corners at wakefield in one race...and only on the startline in the others,i think i managed a second alap faster... it was quick for a cb tho,make no mistake
he's on an rvf now i think.
stimpy
Posted: Fri Apr 10, 2009 2:41 pm
by bbanna
Thanks for the info and yes I was refering to the CB400 (NC31) vs the CBR400RR (NC29).
Just one follow up question here. What kind of performance differences are there between the two? Is it considerable or marginal?
Thanks.
Brian
Posted: Sat Apr 11, 2009 9:48 am
by Cammo
bbanna wrote:Thanks for the info and yes I was refering to the CB400 (NC31) vs the CBR400RR (NC29).
Thanks.
Brian
I think you'll find that the power output is pretty similar, but the nc29 produces better power at higher revs (cams, compression, ignition, etc).
Posted: Mon Apr 13, 2009 10:20 am
by stimpy
you could never compare the 2 really in performance and handling..the cb that is racing here is heavily modified and is only just hanging onto stock nc23's and 29
summin to think about
stimpy
