NC30 Problem
Posted: Thu May 29, 2008 4:32 pm
Hello there guys,
Okay well the problem with my NC30 is that when its revved it gets to 5k then backfires and splutters all over the place, unrideable, rev counter darts up and down.
its on and off as in one minute itl start, next minute itl do that.
Replaced pulse generators (pickups) and the problem went for about a mile (however, at the same time i stabbed the CDI a bit with a screwdriver - was told it can help) then problem came back, same symptoms, backfiring running real rough.
Bfore this, I had run the bike daily, so i dont see how crap could of got into the carbs etc..
Reg-rec is fine.
Tips please guys, im almost certain its the CDI just want t o make sure before switching it out, everything else is working correctly and now horrible engine noises.
From what I can gather it is the "ingnition not advancing correctly"
Thanks, just need the reassurance before I shell out on a CDI.
Reg-rec is fine.
