wont rev past 8-10k
Posted: Tue Apr 07, 2009 1:31 pm
by Spike16
as per title i took my bike out for a test ride today and its not right, it pulls well up to about 8-10k then dies, its like its got a missfire or the fueling is way out but it just wont get through that boundrie and if it does it rounds very rough
the carbs have been rebuild and iv fitted an extra washer under the needles and a foam filter and it has a race can on a standard system
would much apreciate any help please
Re: wont rev past 8-10k
Posted: Tue Apr 07, 2009 1:54 pm
Is this the first time you've ridden them since you've messed with the carbs?
Sounds like somethings not back together quite right, maybe one of your sliders is sticking?
Posted: Tue Apr 07, 2009 2:50 pm
by Spike16
yeh it is, il take them off again and have a look
Posted: Tue Apr 07, 2009 8:01 pm
by royster81
and while they are off maybe look at setting the A/F screws to 2.25-2.5 turns
Posted: Tue Apr 07, 2009 8:53 pm
by Spike16
ok took airbox off and pushed the slide up and there not jaming or anything so i assume there ok
im going up to smevs to borrow a standard filter to see if it is the foam filter that is at fault, gona take extra shim out tonight so the bike is totally standard as to what it was before the rebuild so when i will know if its the filter or not, then gona play with shims and different slides to find the optimum
tbh im pritty sure it will be the filter, if it is il keep it out so the bikes running good and when i get a system and can afford some dyno time put it back in and get them to set it all up
whats the theory behind the af screws again mate?
Posted: Tue Apr 07, 2009 10:23 pm
by Cammo
Your main jet sizes are too small for the filter.
Forget mucking around with anything else on the carbs, just get the mains right.
128's all round would be a good safe starting point with the foam filter.
What size jets are you currently using?
