Rear wheel bearings
rabutcher
Rear wheel bearings
Post by rabutcher »
Does anyone know were i can get them cheaper than wemoto, and also am i right in thinking 36mm socket for the wheel nut and 46mm on the socket side
padawan
Bike owned: VFR 400 NC30
Re: Rear wheel bearings
Post by padawan »
Hi rabutcher try ebay, david silver or RickO for the bearings although iirc the rear wheel has no bearings only the hub has bearings - and you're correct to get the rear wheel off you need a 36mm socket to get the hub nut off you need 46mm (the hub nut is a bitch to get off) to do it make sure you have the rear caliper on you'll need to depress the brake whilst trying to take the nut off.
