fuel tap
Posted: Fri Apr 03, 2009 9:50 am
by rabutcher
the fuel tap on my nc30 doesn't shut off, what problems is this likely to cause me.
As it doesn't like starting after being sat for a while
Re: fuel tap
Posted: Fri Apr 03, 2009 9:56 am
The most serious issue that can happen is that fuel leaks into the cylinders, into the sump and causes lubrication issues. It can also cause a hydraulic lock if it fills the combustion chamber with fuel and you turn the bike over..it will clunk
It is worth fixing it...
Re: fuel tap
Posted: Sat Apr 04, 2009 12:45 am
by dx400r
I second that.
It happened to me - 1/4 of a tank into the sump.
One of the scarest things thats ever happened in all the time I have worked on the bike. Thankfully (or not) all the fuel ended up in the sump which saved me bending something.
Needless to say. I fixed the fuel tap immediately ;)
Re: fuel tap
Posted: Sat Apr 04, 2009 9:33 am
by GF Racing
We have several good used NC30/35 fuel taps in stock.
£30 delivered assuming UK postcode - inc. VAT.
Paypal as per email below is fine BTW.
