Wanted 3tj front calipers
dobbslc
Post by dobbslc »
As in the title I need some good front calipers for a 3TJ as I've just found one of mine has a stripped thread on the pad pin area.
Also do the FZR calipers with two pad pins (the older ones I think) fit the 3tj as they look the same exept the pads have two pins holding them in?
Thanks chaps.
KIYOSHI
Re: Wanted 3tj front calipers
Post by KIYOSHI »
Tel matt on 07745704599 he has some. Tell him Alex told you to call.
Post by Evilchicken0 »
3TJ calipers only fit the TJ - the earlier ones have a bigger bolt spacing.
3TJ = 83 or 85mm
Others are 100mm.
