CBR400RR - Spring Service...
Posted: Thu Mar 26, 2009 5:05 pm
So after spending nearly £700 on bit to get the 'Blade through the MoT, figured now was the time to crack on and get the work done.
Day 1
Pulled the bike up onto the (lovely) Abba Stand... now where to start?
Stripped off all the fairings, bar the front piece, put safely to on side for a good clean. Managed to snap on of the fairing bolts, bloody ally crap. Phone call to make Monday morning for a replacement, maybe! (Removed hanger bracket, Drilled out snapped bolt, cleaned and remounted!)
Disassembled the front end, forks off, yoke out, bearing all seem good, if a little dry.
(Pictures to come later)
Exhaust Off... it's rotten. 7/8 studs unbolt from the engine but none snap off, Good Job.
The Hole made by jacking it up on a car jack, it's also been flattened here too...
16 Year Old Headers... seen better days.
Managed to snap a bolt in the End Can... 2 seem to be original, the snapped one is some sort of cheap knockoff.... bloody crap again! (Drilled, Tapped, Fixed!)
Cleaned up the forks with some good old elbow grease...
Dark Now, Tea Time!
Day 2
Started off today by cleaning and polishing the forks and exhaust hanger. Nice and shiney again!
In the meantime, the old man seperated the nuts from the Exhausts Studs, after left to soak over night in what can only be called "Miracle Spray" AKA Rust Shock. Once they were all seperated, we refurbed all the Nuts & Studs, almost as good as new. Tap & Dye sets do come in handle for getting the shite out of threads.
Re-Greased and Re-Packed the Bearings, nice and notch free, thankfully, rebuilt the front end, minus Wheel... set aside for the new set of rubber. Top Yoke nut had to be tightened to 105nm... fook thats tight. Give up at 90nm for fear of shreading the threads. It's already 4x tighter than when it came off!!!
Spot the canine helper!
Dropped the back wheel out... Need to get in and clean that swingarm, now I can see it.
Thread lock on the Studs bolted back into the engine, ready for the new stainless system.
Wheels given a good clean, don't want the nice man who changing the rubber to get dirty hands!
Drained the coolant out ready for replacing.
Still to do... Oil Change, with Filter Replacement. Fit new Exhaust. Change Brake Lines to HEL Stainless ones and referbish calipers. More cleaning...
Day 1
Dark Now, Tea Time!
Day 2
