76 Carb hoses-fuel tap,which one goes where? 'On' or 'Pri'
arkell
Post by arkell »
GK76A carbs, back on the bike, got a fuel line on the left and right of the carbs, which one goes to the 'pri' setting and which goes to the 'on' setting?
Bike is back together now just need to get it running!
timoth123
Re: 76 Carb hoses-fuel tap,which one goes where? 'On' or 'Pri'
Post by timoth123 »
if they are standard hoses they should lie in the right position. but it doesnt matter either way, they both feed fuel at the same time. im guessin you got the vacuum hose on aswell?
arkell
Post by arkell »
yeah the vacuum hose in on there as well, where does that go to incidently?!
Gavsta
Post by Gavsta »
http://gavsta.blogspot.com/2009/01/fuel.html" onclick="window.open(this.href);return false;
Should tell you all!
Gavin.
