NC23 jumping in and out of 6th?
Posted: Mon Mar 23, 2009 8:50 pm
by drifterwannab
All other gears are fine, just when its in 6th you give it throttle it jumps out then catches again when you throttle off
Is it a selector spring?
Re: NC23 jumping in and out of 6th?
Posted: Tue Mar 24, 2009 10:53 am
by drifterwannab
from looking at other posts seems to be worn dog gear on 6th? but have only found cases of this happening on nc29s?
Posted: Wed Mar 25, 2009 10:01 am
by stimpy
apparently its due to a washer thats worn on the gear shaft or summin..it doesnt put enuff pressure on the gear to keep it in...its happened to 2 gearboxes of mine thru racing...1 is about to be rebuilt so i will have more info in it as it comes to hand.
basicly its an engine out and pull apart job no matter what way you look at it...so at the same time spend some cash and fit new bearings n rings so u know when it goes togeather it will be fresh for you
enjoy
stimpy
Posted: Thu Apr 02, 2009 11:25 pm
by drifterwannab
Hi,
have you sorted yours yet? as i could do with a bit of advice as too what exactly will need replacing
cheers
