				SP Fork Seals
				Posted: Tue Mar 17, 2009 1:49 pm
				by beasthonda
				I have a 3TJ fitted with SP forks that have started leaking
Could any one tell me if the fork seals for a standard RR are the same fitted in SP forks.
The local Yam dealler cant tell me!!
Also best places to buy seals from?
Are non Yamaha ones any good
Thanks for any help you can give
				Re: SP Fork Seals
				Posted: Tue Mar 17, 2009 3:19 pm
				by dazzfr400
				both same buddy just done mine.cheers daz
				Re: SP Fork Seals
				Posted: Tue Mar 17, 2009 7:36 pm
				by plodder
				I think they are 43 ID, 55 OD, 10.5 THICK (the markings are on the top face).  Same as FZR1000 EXUP 1989-90
				Re: SP Fork Seals
				Posted: Thu Mar 19, 2009 10:04 pm
				by Motorcycle Solutions
				I supply fork seals for £6 a pair posted and the sp is 10.5 mm and the rr models are 9.5mm...
The 10.5's a bit tight in the RR model forks..
Check out the deals in the traders section
				Re: SP Fork Seals
				Posted: Thu Mar 19, 2009 11:01 pm
				by Taggyd
				you can sort me a set of sp ones if you will please! might as well do em at same time as oil! forgot to mention it earlier!
				Re: SP Fork Seals
				Posted: Tue Mar 31, 2009 3:41 pm
				by beasthonda
				Forks have now been rebuilt with new seals, oil and cleaned.
Made a huge change to the bike.
Also now have full rebound adjustment!!
Thanks to LAJ for seals and advice.
Must confess I had a bloke from work doing the job for me.
He builds dampers for F1 cars for was very happy when he offered to do them for me!!
				Re: SP Fork Seals
				Posted: Tue Mar 31, 2009 11:49 pm
				by Evilchicken0
				Cool - I'm glad it worked out in the end ... what about the shock ???
				Re: SP Fork Seals
				Posted: Thu Apr 02, 2009 11:14 am
				by beasthonda
				Rear shock I think is ok!! feels fine any way
Would like to fit a R6 shock at some point
				Re: SP Fork Seals
				Posted: Sun Apr 19, 2009 11:37 pm
				by poltog
				try DK motorcycles, phone no.  01782250177
poltog@hotmail.com
