NC24/NC30 Carbs
in4thethrills
NC24/NC30 Carbs
Hey Guys N Girls
was wondering , I'm trying to sort out restricting my NC24 , and was wondering are the carbs the same on the nc30/nc24 ? as i have the dimensions for those washers that fit the NC30, or does anyone know the diameter of the washers needed, or is it best to measure the hole?? trying to save having to strip down and leave it dismantled while i source the washers.
hope someone can help
:D :D :D
:D :D :D
Re: NC24/NC30 Carbs
I would probably go with the dimensions you have. The carbs are both 32mm if I recall and with this restriction being a bit of a belt and braces thing then stick the washers in and get a dyno sorted.
