anyone brainy... Please Help.. Ignitor question.
MarkSwan
Hello Guys..
Reet, I have an FZR400, its an 87 model that was registered abroad (brought over here 10 yrs ago). and its my little project.
IM having toruble figuring out which ecu/cdi/ignitor to use on it, as the Wiring loom looks a bit odd..
Its got a 4 pin connector and a six pin connector, aside from the in the four pin, only two are actually in use and in the 6 pin only 5 are in use.. I have no idea what part number the cdi should be.
Anyone have any idea which one it could be ?
Thanks in advance..
Im also trying to find a set of front disks for it
Mark
Thanks in advance..
Mark
Taggyd
Re: anyone brainy... Please Help.. Ignitor question.
I have a set of discs! They're the ones without an offset (i.e they are totally flat) aren't they?
if so i do!
you could try the deresticted cdi that comes up on ebay every so often, they are 6 and 4 plug!
taggy
if so i do!
taggy
MarkSwan
ah i wasnt sure if that would work as that has some wierd wires coming out of it.. which i have no idea what they are or where they do lolTaggy wrote:I have a set of discs! They're the ones without an offset (i.e they are totally flat) aren't they?
if so i do!
taggy
Mark
http://www.madsi.co.uk/models.aspx" onclick="window.open(this.href);return false;
Go to the link and get an ID on your model ... do it by the pictures and frame number (also on the V5 doc) that will give the correct model and help with buying a new CDI - there are some chinese modified CDI's on the Bay with also ditch the speed restriction .... but that didn't come in till 1988 on the 3en1 EXUP model.
MarkSwan
aye its a 1wg model (non exup )..
Genesis Model then.
Taggyd
did see a derestricted cdi on ebay advertised with a pic of the geesis next to it, was from china though!
my 3en1 has an 8pin 6 pin set up and these had 6/4 set up so they may be correct for the genesis model!
but dont quote me on that! :D (waiting for the obvious!
MadSi
I've got a 2tk TDI I would sell for the right cash - you may need the loom as well but pretty sure I have that also :)
Si
Si
