GK76a SP Carbs - Help!!!
TeamGSXR
Hi all,
I've removed the carbs from my bike today (1990 SP) to give them a complete overhaul.
The screws in the carb tops were corroded quite badly but all came undone apart from one. A relative provided some assistance by putting some impact on the screw. Unfortunately they have managed to piss me off and snap the plastic carb top, and break the cast!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
... Not HP!
Does anyone have a set of SP carbs I can buy or advise if another model uses the same cast?? Gutted.
Thank you,
J
Thank you,
J
- Variablevalves suck
Re: GK76a SP Carbs - Help!!!
Hi J,
If the alloy used is weldable i can repair rebuild the alloy so if you completly stuck PM me.
Chris.
Chris.
reggit
Are these the same bodies as on the Bandit 400? Mikuni BST33's - if so I've got a set I bought to pinch parts from for mine and are now surplus to requirements and likely to find themselves on evilbay very soon. The castings are good, but look to have sat for years and are gummed up.
Honda CB1000 'Big One'
Yamaha RD350LC
Yamaha RD350LC
TeamGSXR
Thanks Chris. I've chucked a load of araldite underneath the screw plate and along the break. I *might* be lucky and get away with it... I'll find out pretty soon!
Hi reggit - they are 35mm ones that have a TPS on the side? So unsure if the castings are the same.
Cheers,
J
Cheers,
J
reggit
No, mine will be unsuitable for you.
cheers,
Dave.
cheers,
Dave.
Yamaha RD350LC
Yamaha RD350LC
arkell
i have a spare top bit if you want it (sounds like the bit you cracked) , surplus as not repairing my carbs just bought a new set!
TeamGSXR
Cheers mate... It's not just the top bit though... It's the cast too. Where the plastic top is screwed into
gsxr400 racer
katana or gsxr carb look for 35 mm on a bigger bike if suzuki you will find a match even if its not a 76a
TeamGSXR
Thanks gsxr400 racer :)gsxr400 racer wrote:katana or gsxr carb look for 35 mm on a bigger bike if suzuki you will find a match even if its not a 76a
gsxr400 racer
my suggestion would also be a rf 600 carb since those are the carb kits that fit
