Clutch springs
				dobbslc
Clutch springs
I,ve just rebuilt my 3TJ engine & measured the clutch springs & they are 33mm long according to the 3TJ manual they should be 41mm!
I also checked the spec for an older fzr which said they should be 33mm long.
Is this right? are there two different sizes depending on what model you have?
I don't think the springs have shrunk that much but if they are the wrong ones that would explain the bloody clutch slip.
Help please...
Help please...
Re: Clutch springs
Just fit new ones
