rear wheel
Posted: Sun Mar 01, 2009 10:40 am
by rrsp
does the sp have a different rear wheel than the rr, or have i got a wheel from a 3en or something, when it lines up with the front sprocket ,the disk on the otherside is way off, the disk is in-line with the bearing. as with my sp one the disk stands away from the bearing, iwill have to look at the casting numbers on both wheels, does any one know the different numbers for what bike, !
Re: rear wheel
Posted: Tue Mar 03, 2009 11:52 am
by Taggyd
do they have a different caliper hanger? i know i had problems with one that didnt fit on the rr because it was thinner!
the sp wheel has captive spacers aswell so if you havent got them its not an sp wheel and might need the thicker hanger to line up! or the other way round, maybe you have an sp wheel with rr hanger?
the rear wheel code for the 3tj rr is r69 though!
taggy
Re: rear wheel
Posted: Wed Mar 11, 2009 11:45 pm
by rrsp
cheers for that taggy, it is a rr wheel as my others have captive spacers in, what a bummer as i have just had all my wheels painted then notest this one doesnt fit, :evil:
Re: rear wheel
Posted: Thu Mar 12, 2009 10:32 am
by Taggyd
you might be able to get away with it by adding a washer onto the spindle to space out the hanger so you can still use it? not absolutely sur it will work but might be worth a try?
