Flywheel/rotor puller??
				dobbslc
I need a puller to get the rotor off my crank (3TJ)does anyone know what size I need or who sells them?
- cagiva996
Re: Flywheel/rotor puller??
take out a bar end wieght and use that as your puller-it works!!
				dobbslc
OK tried the bar end weight but no joy, This is a BDK light weight rotor and won't budge.
I've tried heat, cold, then force but it's not moving any more ideas?
Plastic Explosive ...
				dobbslc
I can get the gun powder type!
- cagiva996
Ring bdk and ask what they use-theyll only be to pleased to give you advice especially as your using one of their products,they must remove and replace them all the time!
Flywheels can be b'stards to get off
				Marb
- Thieving Pikey Twat
Get yourself one of those 2000W heat-paintstrippers (the haridryer on steroids type) and blow dry the rotor for about 10mins. Should pop right off with the barend rotorpuller!  :)
				dobbslc
I got "medieval on it's ass with a blow torch but no pliers" but it still won't budge
I,ve ordered a 4 way flywheel puller so will try that when I get it as the end weight is a bit soft and stripped when I gave it some stick.
				Thunderbike_steve
I'm after one of those rotors, just dont want to pay the price bdk are asking for what is bacially a metal disk. Anyone know where you can get them cheaper?
