My rebuild at last!!
- Jamboy
- Bike owned: 916 ,NC30, CBR600RR, RGV250M
Lost the last tread on the old forum so I'll start a new one here.
I've started to rebuild my NC after a good year and a half now and I've taken some pics to show the progress.
I'll only put a few back up as most of the older members from the old forum will have seen this already.
To this with some powder coating done and new tyres, rebuilt forks
Rear brake line is now also through the swinging arm
Now got some trick alloy rads and a brembo front brake lever/master, and brembo front brake discs now also to go on.
Pics to follow at the weekend on those being fitted.
Living Life, Living The Dream
						- Giffin101
Re: My rebuild at last!!
The bike looks amazingly clean but your back garden to do with a bit of tlc and what on earth are you letting your child play with?
						- Jamboy
Thats the grandparents garden, I think my boy has got the new front fender brackets it his hand too.giff wrote:The bike looks amazingly clean but your back garden to do with a bit of tlc and what on earth are you letting your child play with?
				el_dudino
That's just making me jealous!  I really need to rebuild my NC24 and powdercoat all the mild steel parts, time and money are the limiting factors plus a pregnant wife!  I cleaned my pushbike last night after commuting through the winter and it took a good two hours, she came out 4 times to ask me how long I'd be/moan at me/tell me that she thought I was "only cleaning it"!!!
It's gonna look very nice when it's done Jamboy!
- Jamboy
Got these babies to clean up and fit this weekend
and these 2 to clean ready for fitment later on
						- Jamboy
These also came today to fit back on the fork lowers  :D
				howl
Hi Are you putting a bent end on your rear brake pipe as it connects to the caliper ? Cheers Alec
				wullvfr
- Bike owned: zx9r c1
looking good,very clean!!!!im sure ive seen it posted somewhere before on the previous forum about putting the rear brake line through the swingarm where is it routed???and where to drill etc?
fancy doing myself as it looks very trick.
						- Jamboy
Alec you need a 90 degree elbow banjo to reconnect to the pipe, I'll be putting a pic up of this later this evening for all to see.howl wrote:Hi Are you putting a bent end on your rear brake pipe as it connects to the caliper ? Cheers Alec
				Kermit
Posted before the 11 hr roll-back on the forum but it was along the lines of I have the same shock as you but mine being one that has been converted from use on an FZR400.
Now Im curious about the angle of the shock reservoirs banjo's and line as normally the reservoir would mount on the rhs of the subframe by the passenger rearset (I had to have mine swivelled in to the right when i had it serviced) but your line is pointing 90% to the left...is that on purpose? if is the reservoir going more of less in the normal place but on the other exhaust hanger side of the subframe?
