v4 engine novice
Posted: Wed Feb 25, 2009 5:33 pm
hi, i do hope someone out there can shed some light on this situation! after a few drinks down the pub i bought off a friend a 1990 nc30 it had been stood for about four years after a bit of work ( new battery, plugs ) she turned over was a bit smokey but i would expect that after four years.
the strange thing now is she wont start, i turned the ignition on as usual, presses the starter she tried to turn over then but wouldn't. Gave her a few seconds tried again and still nothing, then the third time i tried i just heard a click and then nothing no signs of life...i have checked all fuses, the battery voltage and looked for any lose bad connections. When i bought the bike it came with an extra loom so i have even tried that.
the battery is reading about 11 - 12 volts when i put a meter across it. Even stranger is if i connect a set of jump leads from the car to the battery ( no engines running ) just to give an extra bit of juice sometimes there will be ignition lights some times not if there is it still wont fire, even if i press the horn you can barely hear it?
does any one have any thoughts? also if anyone has any manuals etc as i am totally working blind at the mo, i have never worked on a v4 engine before. i also own a 929 blade so i know my way fairly well around honda's but this small little engine is really stumping me!
