NC35 head lamp switch
Hi my nc35 does not have the means to turn the headlamps off with the ign. on
is this normal ? not very good for starting the bike with a low battery.
cheers
alistair
cheers
alistair
Re: NC35 head lamp switch
Hey mate, many switches are blanked off so that there's no option to turn the lights on or off.
All grey imports that come into Australia have this done because it's illegeal here to ride with lights off.
Check the switchgear for where the hole has been filled.
- Bike owned: zx9r c1
unless you are doing really short continous journeys then i don't think a flat or low battery will be an issue.
the charging system if in good working order,is very efficient at keeping the battery fully charged up.
william
william
Cheers, that expanes it, my l/h switch has the blanking plug,where a switch should be.
anybody know if there is a switch gear that would fit,with a on/off switch
many thanks
alistair
many thanks
alistair
