NC30 Seat Mounts and Cable Routing
- Bike owned: VFR400 NC30 91'x2 Zxr750L2'x1
Ello all,
Could anyone provide any info on how the front seat mounts securely? At the mo mine just slides underneath the tank bolt and then has two threads the each locate into the fairing, one on each side but i don't think i'd trust it to be anywhere near rigid enough to be ridden properly, Am i missing a bracket maybe?
Alsoooooooo
Anyone know how the clutch and throttle cables route correctly? Cannae work it out, keep thinking i've finally found it untill i realise it's totally wrong :/
Pics would be ace if anyones willing.
Cheers :D
Alsoooooooo
Cheers :D
Re: NC30 Seat Mounts and Cable Routing
The seat is held to the tail unit by just the 2 bolts underneath.
Can't help you with the cable routing, I just whack them wherever they fit as long as they don't get in the way of the steering.
After having a nose about at a NC30 at oulton today, Finally discovered about the front seat bolting to the tailpiece before it's fitted to the rest of the bike, I had no idea you mounted it beforehand, so i was totally clueless till now, Happy days :)
Oh, Found a comfy place for my cables that doesn't put any strain on them so i'm all sorted :)
Cheers for the reply Stickshift
