Managed to get bike running, WAHOO still need advice please
Posted: Sun Feb 15, 2009 4:59 pm
Right ... so close :)
I couldn't sleep much last night thinking about the 400RR and I was going through in my mind all possibilities, see most of what I have read online says you need 20mm when setting the float height and my factory pro stage 3 instructions says I need 15mm, I did set them to 15mm and thats at its absolute max and 20mm is not possible.
I did read that the carbs on the SP2 model were different to other GSX-R 400's and I think thats where the confusion is.
So today I decided to do the opposite of what I have been reading online and I LOWERED the float heights to 12mm each.
Once I did this I tried to start the bike, no joy, then I tried to bump it, still no joy but it sounded better like there was more chance of it starting.
I had all but given up when I thought I will give it one last go but try something different and this is what I did.
Ignition off, choke on full, I then pulled the throttle right back and held it there, put ignition on and hit the starter button, the engine began to crank and crank and about 4 seconds later the think started YAYYYYYYYY.
I took some videos to better demonstrate whats going on with the bike as follows :
This video shows the bike about 1 min after it started, I quickly got the camera out and started to record.
As you can see, plenty of white smoke which soon stopped, and you can also see bits of oil that have been spat out the exhaust against the back door, this was before I did a carb overhaul so I am not sure if it still does this.
You can then see me revving the bike and adjusting the idle to try and get it as low as poss, the bike rev counter STARTS at 3,000rpm and it doesn't want to go much lower than this.
http://www.youtube.com/watch?v=s1KOVss_tCk
Listen to this video around the 14 second mark, this is typical of what happens, idle is ok, ya rev it or do owt and the revs drop and the bike dies :
http://www.youtube.com/watch?v=xa4cv4SQpCA
Finally .... I sat on the bike, pulled off slightly then pulled the clutch back in and put the bike in neutral and this action stalled the bike, again no good if am at a set of lights, so why is this happening ?
http://www.youtube.com/watch?v=9MxAq5F-qKE
The main thing is, I can get it started :D so I can now test compression when the engine has been run to get an accurate reading and I can also set idle screws correctly with me coloutune.
But before I do any of that this is my question that I do not have the answer to .....
How come the bike started with the throttle back to the stopper ? whats happening and the relation in the carbs when I do this ? and does this suggest that the needles need to be lowered or raised in order to compensate for this ? or is it all idle ? I just don't know.
ANY input would be much apprecaited.
Matt - Soon to be (with any luck) super fast 400RR Road Racer :D
