Headlight bracket??
osian
Headlight bracket??
Post by osian »
Anyone know of any floating about or are they as rare as clocks?
houdini
Re: Headlight bracket??
Post by houdini »
i think i have some let me check it wont be till wed though at work for the next two days
osian
Post by osian »
Any luck?
houdini
Post by houdini »
i know i have some cant find them at the minute
osian
Post by osian »
FOund some now thanks.
Now, does anybody know what size the 2 bolts are that attatch the bracket to the bike?? thanks
Bodhi
Bike owned: 1995 Honda CB400 SF Version R
Post by Bodhi »
Hey Osian, where'd you manage to find the brackets, if you don't mind me asking. My bike came with universal brackets that are clamped around the forks, which I don't like, and I've always wanted to replace them with the standard ones that bolt onto the normal bit.
Ensie 27
Post by Ensie 27 »
Bodhi wrote:Hey Osian, where'd you manage to find the brackets, if you don't mind me asking. My bike came with universal brackets that are clamped around the forks, which I don't like, and I've always wanted to replace them with the standard ones that bolt onto the normal bit.
Sounds like you're going to need the whole bracket like below. What model is your bike?
Bodhi
Post by Bodhi »
Hey Ensie.
Actually that bracket is already on my bike, so i've no idea why the headlight holders and headlight were taken off and changed. Who knows what happened our bikes before they got to this country.
Just looking at the bracket and holders though, makes me realise that there's nowhere for the indicators to go, hmm, where do they normally go on the standard mountings? you see the headlight holders on my bike have another hole in the body of it that i mounted the indicators through.
meno
Post by meno »
they go in the holes you see at the bottom of the bracket pictured bud, had to use some bigass washers to fit aftermarket ones there on mine.
osian
Post by osian »
If you want some bodhi you can buy a set off me as i got 2 sets which were listed on ebay as engine mounts lol!
Let me know osian AT live DOT com
