bogging down
billy
bogging down
Post by billy »
hi there guys, just bought a gsxr 400 gk76a for my first bike, now my problem being is that when i start it it starts and idles fine, when i blip the throttle it doesnt die but just struggles to rev up? ive been told to do the o rings and am currently trying to get hold of these and the float bowl gaskets, will this solve my problem or should i be looking deeper?
also im after the front fairing bracket, the frame work type thing? if anyone has one spare they would like to sell that would be very handy
thanks in advance
bill
Chalky
Re: bogging down
Post by Chalky »
Hey,
Welcome to the forum and congrats on the new bike. Any pics?
What's it like starting, does it fire up straight away?
billy
Re: bogging down
Post by billy »
no pics yet but i will do when i get 5, it starts fine and sits on tick over, when revved it doesnt die just struggles to pull through the revs
Spinal
Re: bogging down
Post by Spinal »
Hi, I had the same problem on my gixxer 600 after fitting a carb kit. It had a real bad flat spot over about 4/5000 revs where it was bogging down badly.
One of the parts in the carbs called the valve piston was cracked, so the needle was loose, messing up the fuelling. At these revs it was badly over fuelling and bogging down as it drowned the engine.
There's a really good site called Alpha sports, which has breakdown diagrams of all parts. The 400 isn't listed, but other models of the same year are which might be helpful. (I've heard Bandit 400's have a lot of similar parts) They're in America, but will ship to the UK and have parts I couldn't source in England.
Hope this helps.
Austyn
Re: bogging down
Post by Austyn »
I've still got a few of the float perch and mainjet holder 'o' rings if you want some, just PM me your address and I'll post them to you.
wullvfr
Bike owned: zx9r c1
Re: bogging down
Post by wullvfr »
it definately sounds like the bike is flooding itself when you try to open the throttle........
do you get any backfiring at all or any signs of black smoke coming from the exhaust?
there could be many reasons for this,you may need to remove the carbs and visually check them....pay extra attention to the floats and set the height correctly....i would maybe suspect this as the culprit!!!!
william
billy
Re: bogging down
Post by billy »
ive taken the carbs apart they were very grubby, but everything seems to be in order although i cant see were to replace the o rings, and how do i check float levels?
thanks again
Chalky
Re: bogging down
Post by Chalky »
This should help answer some of those questions
http://tonysleep.co.uk/gsxr400carbs" onclick="window.open(this.href);return false;
