Xenon bulbs
Wacko Jacko
Xenon bulbs
Post by Wacko Jacko »
Interested in buying some xenon bulbs for a VFR 400 NC30 jap import which bulbs would i require i found some on ebay would these be ok?
http://cgi.ebay.co.uk/HONDA-VFR-RFV-400 ... 240%3A1318" onclick="window.open(this.href);return false;
Also found these which look cool let me know what you think.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0286256053" onclick="window.open(this.href);return false;
wullvfr
Bike owned: zx9r c1
Re: Xenon bulbs
Post by wullvfr »
they h4 bulbs are uk spec and do not fit the jap spec lights correctly,you can doctor them to fit in the headlight but chances are they won't sit as they should.
jap spec bulbs are 60/35w........
i have jap spec bulbs in at the moment but i have had the h4 bulbs fitted previously......
the other problem with the uk h4 bulb is they are 60/55w so a jap spec bike without a low beam relay runs the risk of burning the switch.
hope this helps
william
Wacko Jacko
Re: Xenon bulbs
Ah thanks mate was a bit unsure about them
Is there any available that fit and work correctly with the jap spec models?
wullvfr
Bike owned: zx9r c1
Re: Xenon bulbs
Post by wullvfr »
other than the jap spec 60/35w bulbs i don't think so.
your only option i believe would be to purchase uk spec headlights,davidsilver supplies these.....i think they cost in the region of £100 i think.
i use to fit the h4 bulb by snipping one of the tabs off and it would slot in,come mot time though the headlight aim was off but on the road i never experienced any problems.........but the downside is the possibility of burning the switch out.
william
Spike16
Re: Xenon bulbs
Post by Spike16 »
I have those led bulbs on my bike, there very bright and suck less juice than standard bulbs so thumbs up from me
iv actually had people who were following say how powerful the brake lights
thrasher
Bike owned: nc30
Re: Xenon bulbs
Post by thrasher »
do the relay mod and fit these.
http://cgi.ebay.com/ebaymotors/H4-Bulb- ... enameZWD2V" onclick="window.open(this.href);return false;
headlight aim is spot on and much brighter.
wullvfr
Bike owned: zx9r c1
Re: Xenon bulbs
Post by wullvfr »
thrasher wrote:do the relay mod and fit these.
what a buy that is..............
wish i had seen them before!!!!
william
Wacko Jacko
Re: Xenon bulbs
That sounds good what is the relay mod. Is it easy to do and what does it involve?
thrasher
Bike owned: nc30
Re: Xenon bulbs
Post by thrasher »
http://www.mediafire.com/file/ndmozjylo2o/relay" onclick="window.open(this.href);return false; mod.zip
gratuitously nicked from the old forum :D
pretty straightforward to do.
you can use a 30amp 4 blade relay instead of 20amp. been running mine nearly everyday for 3 years no problems.
Re: Xenon bulbs
Those laser-cut adapter rings look ok.
You can also just mod the headlight itself as documented below, its not too difficult and takes about 10 mins once you can get to the headlight :)
http://webpages.charter.net/bpeloquin/H4mod.html" onclick="window.open(this.href);return false;
