SP1 or SP2 Calipers?
J.B.
Hi all. I have some plans to upgrade the brakes on my RVF including SP1 or SP2 front calipers. These are slightly different (as are the master cylinders & rotors on these models) SP1 calipers have 32 & 34 mm pistons gripping 3.5 mm min. thickness rotors. SP2 calipers have 30 and 32 mm pistons gripping 4 mm min thickness rotors. Does anyone know which calipers work better with the NC35 OEM rotors?
Thanks, Jimmy
Thanks, Jimmy
Re: SP1 or SP2 Calipers?
It won't matter which you go for, they're much of a muchness and both will work well with the standard discs.
