Turn light problem
Turn light problem
Hi all .....my '91 nc30 having problem with turn light.Already change new turn signal relay,but still not OK.When press button,the light always ON and not blinking.Any suggestion??
Re: Turn light problem
Sounds more like its wired wrong. Check the wires in different ways.
Hi.how to check the wire different ways???ryancusick wrote:Sounds more like its wired wrong. Check the wires in different ways.
Does the front and the back indicators both stay on?
Have they ever worked properly?
Take off the seat unit and check the wiring under the pillion seat. All of the bullet connectors from the indicators should be plugged into corresponding coloured wires.
It sounds as though the turn relay isn't wired up properly.
Check over the wiring diagram:
http://i19.photobucket.com/albums/b171/ ... alloom.jpg" onclick="window.open(this.href);return false;
What he said, just pull the bullet connectors out and plug them in different combinations. On the RVF there are three females and only two coming from the aftermarket indicators.Stickshift wrote:Does the front and the back indicators both stay on?
