Fuel Tap pipes ?
Fuel Tap pipes ?
Three pipes leading off the fuel tap on the tank 2 larger one which I think is the fuel pipes to carbs and a third smaller one which is flapping in the wind on my bike. No fuel is leaking out of it tho.. Is it a breather where should it go ?
Bike is gk76a 1990
Bike is gk76a 1990
Re: Fuel Tap pipes ?
Wow a friend of mine had a look during our lunch break found out this pipe leads to a small hole in one of the inlet manifold pipes. It now runs like a dream.
One to remember if you remove the fuel tank.
- Psychosomatic88
You mean the vacuum hose? better keep that attached
Going on the internet is like owning a gun... Just point, click, then shit your pants waiting for the Police to turn up.
Thats exactly what it is - im surprised that the bike runs at all without it attached!
Hey - reading about the fuel pipe issue you had - I've got one too. Has yours got two fuel feeds to the cabs then? Plus one vacum? I'm restoring one thats been standing but the tank has been removed and there were no pipes with it. My fuel tap has two pipes - a fuel and a vacum I thought - and there is a third pipe exit in the middle of the tank. Do you know if the third one is a breather or overflow??
yup its an over flow from when you fill the tank, open up your tank and youll see a small drain hole, it feeds to this outlet in the middle of the tank underneath.
